OctalByte
Newbie level 1
- Joined
- Apr 8, 2013
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,313
Hello,
my apologize if this question has been asked before; I searched these forums and none of the older posts were able to help me. What I am attempting to do is create a VGA controller from a Lattice MachXO CPLD in Verilog.
The Problem
I am attempting to display the color red with a resolution of 640x480 using a 25.175 MHz clock internal to the CPLD; however, when I plug the CPLD into a monitor I get an "Out of Range" message.
What I've tried
I have simulated the code in ModelSim, and everything appears to look good save for one issue. When I count the amount of time steps that have occurred from the during the V-Sync display zone (when H-Sync is drawing) and divided it by the frequency of H-Sync, I get 479 pulses -- one short of the 480 lines I should be drawing. I don't understand where this could be coming from as I've check my timings many times, and I suspect that this may be a symptom of the problem, but I'm not sure. Below is my code, and pictures of the timings from ModelSim. I have exhausted all of my other resources trying to figure this problem out, and I would greatly appreciate any help. Thanks.
The Problem
What I've tried
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 module Top(RESET, H_SYNC, V_SYNC, RED); input wire RESET; output wire H_SYNC; output wire V_SYNC; output wire RED; wire rgb_en; /*** Test Bench Code ***/ //reg osc_clk, reset; //initial begin //#0 reset = 0; //#0 osc_clk = 0; //#2 reset = 1; //end //always #1 osc_clk = ~osc_clk; OSCC OSCC_1 (.OSC(osc_clk)); /*< IP clock module for Lattice CPLD >*/ Controller CNTRL(.NRST(RESET), .CLK(osc_clk), .H_SYNC(H_SYNC), .V_SYNC(V_SYNC), .RGB_EN(rgb_en)); assign RED = (rgb_en ? 1:1'bz); endmodule
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 module Controller(CLK, NRST, H_SYNC, V_SYNC, RGB_EN); input wire CLK; /*< CLK input from Top module >*/ input wire NRST; /*< Reset input from Top module >*/ output reg H_SYNC; /*< Goes to VGA Horizontal Sync >*/ output reg V_SYNC; /*< Goes to VGA Verical Sync >*/ output reg RGB_EN ; /*< Enables RGB values durning display time on H_SYNC >*/ reg [10:0] h_counter; /*< Tracks amount of pulses from CLK >*/ reg [19:0] v_counter; /*< Tracks amount of pulses from H_SYNC >*/ `define H_SYNC_PULSE 11'd96 /*< Length of Sync Pulse >*/ `define H_BACK_PORCH_END 11'd144 /*< Pulse len + Porch Len >*/ `define H_FRONT_PORCH_STRT 11'd784 /*< Front Porch Len - Max >*/ `define H_COUNT_MAX 11'd799 /*< Max line pulses for resolution >*/ `define V_SYNC_PULSE 19'd1600 `define V_BACK_PORCH_END 19'd28000 `define V_FRONT_PORCH_STRT 19'd408800 `define V_COUNT_MAX 19'd416799 /*** State Machine for H_SYNC ***/ always @(*) begin /* If the vertical sync line is not in the display zone, keep H_Sync low */ if(!(v_counter > `V_BACK_PORCH_END && v_counter < `V_FRONT_PORCH_STRT)) begin H_SYNC = 0; RGB_EN = 0; end /* If the vertical sync line is in display zone, allow H_Sync to go through its procedure */ else begin if (h_counter < `H_SYNC_PULSE) begin H_SYNC = 0; RGB_EN = 0; end /* If H_Sync is in the display zone, enable RGB */ else if (h_counter > `H_BACK_PORCH_END && h_counter < `H_FRONT_PORCH_STRT) begin H_SYNC = 1; RGB_EN = 1; end /* During the Front Porch period, disable RGB */ else begin H_SYNC = 1; RGB_EN = 0; end end end /*** State Machine for V_SYNC ***/ always @(*) begin if (v_counter < `V_SYNC_PULSE) begin V_SYNC = 0; end else begin V_SYNC = 1; end end /*** Counter logic ***/ always @(posedge CLK) begin if (h_counter >= `H_COUNT_MAX || !NRST) begin h_counter <= 11'b00; end else begin h_counter <= h_counter + 1; end end always @(posedge CLK) begin if (v_counter >= `V_COUNT_MAX || !NRST) begin v_counter <= 11'b00; end else begin v_counter <= v_counter + 1; end end endmodule
