asrock70
Full Member level 4
In the device I have an SMD trimmer 3x3mm 10k 5% linear, +5V working frequency in the order of kHz, .
Used to set the operating point during calibration.
Sets the current in the order of 400uA to 4000uA .
The device is calibrated for a normal room temperature of 25C.
If the temperature is more or 10C higher or lower, it is already reflected in the dynamic accuracy of the device, the error of 1.5% and especially the range of applicability, decreases or increases by up to 10% .
It usually doesn't matter, but I'm still considering the possibility of enabling self-calibration in the new version.
This means adding a differential amplifier something like the INA145 and replacing the mechanical trim with a digital potentiometer any as AD5160.
That brings us to the questions
If I use a digital potentiometer, will any parameters deteriorate against the mechanical trimmers?
Whether dynamic, noise, temperature stability, long-term accuracy or anything else?
Are there any digital potentiometers with a switch? In addition to the 0-10k resistor, they can be in a state of high impedance .
