I see... First, your question is not silly at all... Second, I liked pointing out that joining the MT1's is possible.
The difference is that, in his case, a floating power supply is needed to trigger the triac gates. In mine, the voltage of MT1's are rather stable (connected to a voltage source as the mains).
Added:
A floating power supply is easily done by a transformer.
In my case, I use a resistor (or R + C) powered by the mains voltage to provide the gate current pulses.
The control is usually done via an optocoupler as in a regulated battery charger or directly as in a voltage stabilizer (by steps).
