Tri-state simulation
dileep4111
Junior Member level 1
In I O cell characterization , while keeping input voltage to some fixed voltage, moving the enable signal from enable state to disable state, PAD pin is left floating. For example if PAD voltage is at 1.62 volts , moving the enable pin from enable to disable state, PAD voltage is just coming to 1.6 volts. It this is the case how to find the transition time for PAD pin and propagation delay for enable pin and PAD pin.
thanks
