Xavipersonal
Junior Member level 1
I have solved an differencial equation using the Euler Fordward method. It was not accurately enough. So I am thinking to use the trapezoidal rule but I have read also that this method takes a lot of time until it converges. The other option was the runge-kutta equation because it is even more accurate than trapezoidal but i would like to know if is runge-kutta converging faster than trapezoidal method or which advantage presents?
Thanks a lot in advance
Best regards,
Javier
Best regards,
Javier
