Canooski
- Joined
- Jul 8, 2015
- Messages
- 6
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 39
Reference Transmitter
I am trying to design a small pcb board with antenna that will emit a sine wave that some antennas can use as a reference. I am a little unsure of how to go about this or what is the best way?
Should I use a VCO with an amplifier or will this not give me the stability I need? I would also like to change between frequencies within the 902-928 ISM band when needed.
Instead of this should I use a frequency synthesizer where the output is amplifier?
I also looked at the MAX2900 part however it has a differential RF output which I am unsure of how to realize with a whip antenna.
Thanks
Thanks
