Transmitter and Receievers
budder8818
Junior Member level 3
New Jersey, USA
Does anyone have a good website or book that would introduce the fundamentals principles of transmitters and receivers. I am an electrical engineering student specializing in RF and Microwave.
I have good background in electronics, digital design, circuit theory, transmission line theory and signals systems.
Thank you
I was once recommend to read Frerking's book on Digital Signal Processing in Communication systems. See if that can help you. If you are good at DSP, you should jump directly to the latter section of the book.
is there any way to findout whether transmitter is working or not?
The way of findout whether transmitter is working or not, closely relates with the power output of the transmitter. For measuring small amount of power, you may use a simple RF probe connected to any multimeter to measure the RF output level. If the power is more, a field strength meter may be used to be on the safer side as this will not have any physical contact with the transmitter.
can i use bc107 transistor instead of 2N3904?can u highlit difference between two ic's?
when did bc107 and 2n3904 became ic's?
Why dont you start a new thread instead of posting it here?
