Resistanceisfutile
Member level 4
- Joined
- Aug 22, 2012
- Messages
- 77
- Helped
- 2
- Reputation
- 4
- Reaction score
- 1
- Trophy points
- 1,288
- Activity points
- 2,008
So a transistor is like an electronic variable resistor - as you increase the current going to the base, more current is allowed through from the emitter to the collector? (Please correct me if I'm wrong).
I know they are sometimes used in amplifier circuits and op amps, and I was just wondering if someone could explain to me how.
1. Am I right to think that you have to provide all the power that you want the output signal to have, and you have to use the transistor (with appropriate biasing to prevent saturation or cutoff) to control the power added to the signal?
2. Also, since you can't (so far as I know) just feed a battery directly to an audio signal to make it more powerful, what does a transistor amplifier circuit do differently to increase the power of the signal?
3. Does an amplifier circuit actually amplify the power of the signal, or just the voltage (or the current)?
