transistorguy
Newbie level 3
What I can't figure out is how we can get bigger sign wave out of the small signal?
By using different formulas I came up with the following values to make an single NPN transistor common emitter amplifier. RB1= 10K, RB2=5.1K, Rc=2.2K and Re=470Ω. I used 82pF capacitors for all coupling capacitors. For example if we put 100mV or lower peak to peak in the base and Collector Vcc is +12V. There should be a 0.7V voltage drop at the base/emitter junction. That means transistor is already on. When I measured output at the collector it was DC and there was no sign wave. My question is Once transistor is on with the bias voltage of 0.65 or 0.7 volts how a small ac signal can effect the output which is already been effected by the bias voltage. I understand transistor as a switch but somebody can help me understand how to amplify small ac or rf signals. Thanks
