nimeshasilva
Hi all,
I got a little problem recently. :-(
An HID MH lamp in a UV curing machine (a.k.a platemaker or printing down frame) used in printing industry, is using a Transformer to step up 230V to 800V to supply the necessary voltage for the lamp. the transformer primary is working as an Autotransformer and providing this voltage. and the secondary is just a 11V-0-11V design. I attached the rough sketch of the wiring diagram.
The problem is when the machine is powered up, and after the lamp has ignited, the transformer's 230V winding is drawing ~65A (measured by my clamp Ammeter at point P2) current which is totally unacceptable (the machine is rated to 30A with including lamp, several motors, and all other stuff, but this time, I turned off all other stuff except the lamp) and the main service breaker is tripped due to exceed of the maximum current. but in the lamp circuit it only draws the ~19A (Measured at point P1) which (I think) is the normal current for the lamp. And when I disconnect the lamp and turn the machine on, the transformer primary alone is drawing ~15A and I think its unacceptable too. and the (such a big) transformer is getting hot quickly in the time period which the lamp has turned on and the main service breaker is tripped. which is less than 2 seconds.
It is a big transformer with about 20Kg of weight.
Can anyone help me to solve this problem?
![](https://obrazki.elektroda.pl/87_1319738382_thumb.jpg)
