I am designing a transformer matching network (TMN) for a PA. I do not have ADS PDK but working in CADENCE PDK.
My question is do I have to design layout in CADENCE then export gds file to E.M software such as HFSS/ADS momentum for electromagnetic simulation and optimization?
or can I design in HFSS/ADS momentum then export the gds file to cadence? Do I need to integrate PDK in HFSS/ADS momentum to design TMN.
My question is
What I mean is that do I need to integrate PDK (Process Design Kit) to ADS/HFSS? I have to use the top two metal layer in the technology I used. How to do this in ADS Momentum/HFSS?
Construct Layer database for Keysight or Ansys Layout environment.
BTW, there is no tool which name is ADS Momentum.
Momentum is a EM solver based on "Moment Method" which is a product of Keysight Technology.
ADS is a a name of Design Frame Work of Keysight EEsof.
You can launch various tools on ADS Design Frame Work, ADSsim, GoldenGate, HSPICE, Momentum, HFSS, etc.
Momentum can be launched directly on Cadence Virtuoso Design Frame Work without using ADS if you have appropriate license.
Ok thank you for correcting me. I will make sure to use correct terminology. About launching momentum directly on cadence virtuoso design frame work, this is not possible since I have to use them separately due to some issues.
So I guess I have to mapped the technology layer from cadence to ads. Thanks for the information
The best way is to export your layout design from other tools ( I am assuming you are using Cadence virtuoso) to ADS using GDS file and in ADS layout use Momentum ( method od moment based solver) or 3D EM solver FEM. There is no need to use PDK for Layout only simulation. Another way is to use ADS Interoperability feature to directly synchronize your design with ADS layout if you are using Interoperable PDK.
