[AVR] Transformer Current Ratings.
Titus Manoj Kumar
Junior Member level 2
Sriperumpudur, Tamil Nadu
Hi.,
Thanks for the replies. Got a solution for my previous post and it works.
I've another clarification.
What is the current rating should i use for powering up a 12V relay?
Am using 12V 1amps. Is it Okay?
And also how to determine the current ratings for a device?
Thank you.
current needed to energize a relay all depends on the relay!
how are you energizing the relay?
same with the current capacity - how many lamps?
if there are no marking, look at similar devices [especially the contacts] to get an idea as to current capacity
AT first sight, the thread title is unrelated to the question. Please clarify what you are actually asking for.
