transfer from 0.18um to 0.13um, what are different?
beabroad
Member level 4
difference 0.13 0.18
i was working on 0.18um, now i want to design the first 0.13um chip for me.
i want to know what are different. thanks.
vbhupendra
Full Member level 4
GOA, INDIA
r u porting ur existing design to 0.13u or it is a fresh design ?
beabroad
Member level 4
fresh design.
if you can tell me the methods of porting, i also would like to have a try
scottieman
Full Member level 2
On Top of Silicon
Just want to confirm. You are working on digitlaor analog?
Since it can be quite different in terms of tech. transfer.
Scottie
beabroad
Member level 4
on the analog design, however, the technology is said as digital tech
jerrymelb
Newbie level 6
The biggest difference should be the design rule, I think.
sunking
Advanced Member level 3
if analog, it depond on you supply voltage.
this is to say, if you use high voltage device(i/o device), there is no more difference. but if you core device(1.2v for .13, 1.8v for .18), you must pay attention to the change of the supply voltage.
scottieman
Full Member level 2
On Top of Silicon
In your analog design, you will use minimum channel length (e.g. 0.13um) or scale it, say 5 times (3.g. 0.13um x 5 = 0.65um) ?
Scottie
Syukri
Full Member level 5
Malaysia
Hell yeah scaling.....there will effect a lot of things..........
Roughly said....
Pay attention to secondary effect, and the standby power of your device...
u r designing analog right...so the changes will effect the capacitance value of your devices, sometimes it will make your circuit better due to the less capacitance value...but that is quite simple for digital in analog sometime we need the large capacitance to make a switch
Good Luck...
