<<Transceiver Circuit>>
mitsaklis
Hello,
I am writing here because I need your help. I have to build two transceivers (one for transmitting and the other for receiving). I am going to use a board with a PIC18F452 and a chipcon CC1020. I would like to be able to measure the transmitted and received signal in order to calculate the losses (dB).
So, what I need is:
1. To be able to alter the transmitted power and frequency (use 402-470 and 804-940 MHz range)
2. The code in C language for the transmitter and receiver in order to do the above and also some kind of interface (or otherwise) to acquire the data transmitted and received.
I would be very oblige to anyone who can help in every way.
hi,
I think better u can connect the power detector IC at the Tx input and Rx out to measure the power. The detector ICs u can get from Analog Devices and National Semi at all frequency range.
ks
