MarkV13
Newbie
I have built a small standard circuit as follows:
Li-Ion Battery -> TP4056 Charging Module -> MT3608 Step-Up Converter -> 12V LED strip (approximately 10cm)
Everything works as it should: the TP4056 charges the battery, the step-up converter generates 12V DC for the LED strip (works couple hours from full 4,2V battery). However, the problem arises when I discharge the battery to around 2.7V, and the system shuts down - which is supposed to happen as a safety feature of the DW01A in the TP4056. But the battery naturally recover to around 2.8V over time, and the LED strip turns back on. It discharge itself a bit again to 2.7V, and the cycle repeats. In short, it turns into a blinking Christmas tree (really slow one).
I would like to power a small portable lamp with this setup, but once it discharge, I don't want it to turn on again until I reconnect power to the TP4056.
My question to you is whether anyone has encountered this issue or has any tested alternatives?
