vEjEsE
Newbie level 2
- Joined
- Jun 25, 2014
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 29
I'm wondering how impossible it can be to connect a touch panel (with USB controller) to a PC for it to send X,Y coordinates when an event happens (the panel is touched).
After searching the web I couldn't find more then pieces of information that don't tell the whole story. Most of what I understood so far is that I can buy some touch panel development kit (ebay), create some basic C code that acts like a driver and then use those C functions to handle input on the device in other applications.
Question is, is the touch panel + USB controller + C code enough in order to use the input on the touch panel in other applications that I'll build myself (in C++ or other languages)? And what exactly would the C code be? (I don't want to use the touch panel as a mouse, but independent. It only should provide coords when a touch event happend thru a function call - which would probably be part of the C code mentioned earlier)
An answer like "Buy this [touch panel] and [microcontroller], write this C code [ code ], compile it with g++, run the build and use the [getCoord()] function whenever the [touchHappened()] function returns true" would be too nice to be true?
A multi touch panel would be better (if not too expensive).
Also, I'm working on Linux.
Thank you.
Thank you.
