I usually build a dc to dc converter using sg3525 and ferrite transformer on push pull topology.
I have seen a new board which doesn't have any pwm controller, instead of that, it have a small tsop-6 smd chip, i don't what it is, it have marking 1F on it.
It's 1st pin and 4th pin is connected to ground,
It's 2nd and 5th pin is connected to +ve rail via 3.3k resistor, +ve rail is from 15v zeker diode.
3rd and 6th pins are connected to gate via resistor network.
Is that dual npn transistor?
If so how it is capable of driving two MOSFETs arranged in totem pole method.?
