BRIAN_PENG
Newbie level 3
- Joined
- Apr 17, 2011
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Taipei, Taiwan
- Activity points
- 1,305
Dear all:
I got a problem with high THD degradation on simple 3 stage opamp circuit.
The THD is normal and the same as loop back from PXI-5422 (SG) to PXI-5122 (SA) on Ft(input frequency)=1Mhz sinewave or below. If inputing 10Mhz signal, THD degrad seriously per stage. I've calculated the THD degradation of THS4011, it's around -70dBc in 1Mhz, shouldn't be so worse as in figure I show you in attachment. Is that related to the RF reflection between stages? The PCB routing between stages are short.
Appreciate for your help!
Brianbrian_peng1@yahoo.com.tw
