Total Gm of OTA versus Frequency
Run an ac analysis with an ac unit (1V) input voltage, then plot output-current vs. frequency. Output-current in [A] corresponds to Gm in . Or use 1mV input voltage and get [mS] of Gm.
Dear erikl,
I understood what you mean, but I could not get the desired output.
I have two questions:
1. My circuit input is differential and the output is sigle-ended. How do I apply the input? I applied "ac=1 sin(0 1 1meg)" as the input voltage (in open-loop config.).
2. I putted a capacitor at the output. Am I right?
Thanks.
1. This is correct, but works only if your inputs are DC biased to a working operation point (i.e. within the ICMR).
2. This doesn't matter if you measure the output current. It just could decrease the output voltage bandwidth because of slew rate limitation.
Reactions: an_82
    an_82
