The coreAssembler product is part of the complete set of IP reuse tools available from Synopsys. coreAssembler provides a graphical or command-based environment that guides the designer through the assembly and configuration of an IP-based subsystem. With coreAssembler, designers can easily generate the configured RTL of a subsystem based on the AMBA IP from the DesignWare Library or from IP with an interface that has been packaged for use with coreAssembler with coreBuilder or has an IP-XACT description of the IP to be integrated. IP that has not been packaged for re-use can also be directly imported into the subsystem. With coreAssembler, you can also easily create and package the complete IP-based subsystem for reuse.
