[SOLVED] toggle multiple pins in C
sri5496
Junior Member level 3
UK
hi .
am bit new to programming am using dspic33f..need to toggle multiple pins in C progrm.. would appreciate if any one can help...
You must evaluate '0'´s and '1'´s separatelly.
Try this :
\\ iWord <= input operator pattern in which pins to be toggled bits are designed by '1'
\\ PORTx <= global variable representing I/O uC port
int iTemp = PORTx ;
PORTx &= ~ ( iWord & iTemp ) ;
PORTx |=  ( ~iWord & iTemp ) ;
Use a mask and the bitwise exclusive OR (XOR) operator, ^
PORTA ^= 0b00000011; //toggle bit0, bit1
PORTB ^= 0b00001100; //toggle bit2, bit3
Individual PIN Toggling
RB0 = ~RB0 // PORTB bit0
RC2 = ~RC2 // PORTC bit2
whats the different b/w LATB & PORTB ( LATCH & PORT )
