to interface multiple camera to fpga board
raj18
Newbie level 3
hi ..
i want to give input to fpga board from multiple camera,so can someboby suggest me any suitable way to interface multiple camera because fpga is having only one usb port.
or any kind of usb to serial converter with some data rate comparable to high speed usb ...
milind.a.kulkarni
Advanced Member level 3
Bangalore
can you tried using USB hub ?
raj18
Newbie level 3
thanx for reply but,
actually i need to process all images parallelly,so usb hub cannot be a proper solution for it,as there is only one port and cannot take all images at a time.
Zerox100
Full Member level 6
I guess you have a special fpga development board. You can try another that has more than one. If it does not exist, you can try to make your own special board. It is pretty easy.
