basic electronics
basic electronics
Share this group
Quick Overview
Category
Uncategorized
Language
Total members
159
Total events
Total discussions
Total views
19K
Total albums
to choose capacitors and resistors for a circuit
praman845
Newbie level 1
Newbie level 1
what parameters are there to choose capacitors ,resistors,diodes in electronics circuits.
bilal_flieh
Newbie level 1
Newbie level 1
you have to know voltages and current in your design
Arul271194
Newbie level 5
Newbie level 5
To choose the value of the resistor you have to follow the ohm's law that is
V=IR
so that you can find the value of the resistor by knowing voltage and current value
ravihc1985
Newbie level 1
Newbie level 1
Ofcourse use Ohms Law i.e. V=IR.
But that is not the only thing. You should also know the tolerance, wattage and package of the resistor.
If you are using the resistor across the measuring end, then the tolerance really play are greater role.
If you are using the resistor as current limiting, then the wattage matters, I2R.
