Sep 18, 2008 #1 HolySaint Full Member level 3 Joined Aug 31, 2008 Messages 159 Helped 6 Reputation 14 Reaction score 3 Trophy points 1,298 Location Mars Activity points 2,109 i had set the deinter_ram black_box, why it error again? Error: Memory (deinter_ram/mem) has no write ports and no init file. (B24-1)
Sep 24, 2008 #2 HolySaint Full Member level 3 Joined Aug 31, 2008 Messages 159 Helped 6 Reputation 14 Reaction score 3 Trophy points 1,298 Location Mars Activity points 2,109 about tmax problem waiting for hlp
Oct 14, 2008 #3 HolySaint Full Member level 3 Joined Aug 31, 2008 Messages 159 Helped 6 Reputation 14 Reaction score 3 Trophy points 1,298 Location Mars Activity points 2,109 about tmax problem waiting for hlp
Oct 15, 2008 #4 K kiranks9 Member level 3 Joined Feb 21, 2008 Messages 59 Helped 2 Reputation 4 Reaction score 1 Trophy points 1,288 Activity points 1,648 Re: about tmax problem U need to find out the corresponding init file. when u r laoding the design, then load the init file for that. just check. I also faced this problem
Oct 15, 2008 #5 HolySaint Full Member level 3 Joined Aug 31, 2008 Messages 159 Helped 6 Reputation 14 Reaction score 3 Trophy points 1,298 Location Mars Activity points 2,109 Re: about tmax problem kiranks9 said: U need to find out the corresponding init file. when u r laoding the design, then load the init file for that. just check. I also faced this problem Click to expand... u mean the rom content file? but i dont know what file is the ram init file? can u give a file format or the method to generate ? thq
Oct 17, 2008 #6 HolySaint Full Member level 3 Joined Aug 31, 2008 Messages 159 Helped 6 Reputation 14 Reaction score 3 Trophy points 1,298 Location Mars Activity points 2,109 Re: about tmax problem kiranks9 said: U need to find out the corresponding init file. when u r laoding the design, then load the init file for that. just check. I also faced this problem Click to expand... i use memory compiler to generate the memory and the content files, just like *.rcf. the rom.v which i generate has a initial commond like initial $readmemb("rom_verilog.rcf", mem ); and i put the rcf file in the correct path. is that ok? but the error apperas again.
Jul 7, 2009 #7 G gaom9 Full Member level 4 Joined Oct 8, 2007 Messages 228 Helped 7 Reputation 14 Reaction score 5 Trophy points 1,298 Location China Activity points 3,294 about tmax problem Hi, HolySaint I met the same problem. Have you solved it, please? Thank you! Best regards!
