shobanaganesan
Newbie level 1
I have synthesised the following code in Xilinx ISE PROJECT NAVIGATOR 14.6...The synthesis results show that
Minimum period: No path found
Minimum input arrival time before clock: No path found
Maximum output required time after clock: No path found
Maximum combinational path delay: No path found..
How can this be possible..
The code is posted here..
The text files consist of 16 real values of 32bit each..Help me why there is no timing information encountered?
module sisored(clk,transmitted_data,detected_data);
input clk;
input [31:0]transmitted_data;
output [31:0]detected_data;
wire [31:0]wout,xout,yout,zout;
wire [31:0]r1,r2,r3,r4,r5,r6,r7,r8,r9,r10,r11,r12,r13,r14,r15,r16;
wire [31:0]i1,i2,i3,i4,i5,i6,i7,i8,i9,i10,i11,i12,i13,i14,i15,i16;
wire [31:0]ar1,ai1,ar2,ai2,ar3,ai3,ar4,ai4,ar5,ai5,ar6,ai6,ar7,ai7,ar8,ai8,ar9,ai9,ar10,ai10,ar11,ai11,ar12,ai12,ar13,ai13,ar14,ai14,ar15,ai15,ar16,ai16;
assign transmitted_data=32'b01101101101101101101101101101101;
modqpskRX qpskmod(32'b01101101101101101101101101101101,ar1,ai1,ar2,ai2,ar3,ai3,ar4,ai4,ar5,ai5,ar6,ai6,ar7,ai7,ar8,ai8,ar9,ai9,ar10,ai10,ar11,ai11,ar12,ai12,ar13,ai13,ar14,ai14,ar15,ai15,ar16,ai16);
channel t(ar1,ai1,ar2,ai2,ar3,ai3,ar4,ai4,ar5,ai5,ar6,ai6,ar7,ai7,ar8,ai8,ar9,ai9,ar10,ai10,ar11,ai11,ar12,ai12,ar13,ai13,ar14,ai14,ar15,ai15,ar16,ai16,r1,r2,r3,r4,r5,r6,r7,r8,r9,r10,r11,r12,r13,r14,r15,r16,i1,i2,i3,i4,i5,i6,i7,i8,i9,i10,i11,i12,i13,i14,i15,i16);
//receiver
rec rece(clk,r1,r2,r3,r4,r5,r6,r7,r8,r9,r10,r11,r12,r13,r14,r15,r16,i1,i2,i3,i4,i5,i6,i7,i8,i9,i10,i11,i12,i13,i14,i15,i16,wout,xout,yout,zout);
compare cm1(wout,xout,yout,zout,detected_data);
endmodule
//qpsk modulation:
module modqpskRX(b,ar1,ai1,ar2,ai2,ar3,ai3,ar4,ai4,ar5,ai5,ar6,ai6,ar7,ai7,ar8,ai8,ar9,ai9,ar10,ai10,ar11,ai11,ar12,ai12,ar13,ai13,ar14,ai14,ar15,ai15,ar16,ai16);
input [31:0]b;
//input clk;
output [31:0]ar1,ai1,ar2,ai2,ar3,ai3,ar4,ai4,ar5,ai5,ar6,ai6,ar7,ai7,ar8,ai8,ar9,ai9,ar10,ai10,ar11,ai11,ar12,ai12,ar13,ai13,ar14,ai14,ar15,ai15,ar16,ai16;
modulationqpskRX m1(b[1:0],ar1,ai1);
modulationqpskRX m2(b[3:2],ar2,ai2);
modulationqpskRX m3(b[5:4],ar3,ai3);
modulationqpskRX m4(b[7:6],ar4,ai4);
modulationqpskRX m5(b[9:8],ar5,ai5);
modulationqpskRX m6(b[11:10],ar6,ai6);
modulationqpskRX m7(b[13:12],ar7,ai7);
modulationqpskRX m8(b[15:14],ar8,ai8);
modulationqpskRX m9(b[17:16],ar9,ai9);
modulationqpskRX m10(b[19:18],ar10,ai10);
modulationqpskRX m11(b[21:20],ar11,ai11);
modulationqpskRX m12(b[23:22],ar12,ai12);
modulationqpskRX m13(b[25:24],ar13,ai13);
modulationqpskRX m14(b[27:26],ar14,ai14);
modulationqpskRX m15(b[29:28],ar15,ai15);
modulationqpskRX m16(b[31:30],ar16,ai16);
endmodule
module modulationqpskRX(bo,ar,ai);
input [1:0]bo;
//input clk;
output reg[31:0]ar,ai;
always@(bo)
begin
case(bo)
2'b00:
begin
ar=32'b00111111001101010000010010000001; //+0.707
ai=32'b00111111001101010000010010000001; //+0.707
end
2'b01:
begin
ai=32'b10111111001101010000010010000001; //-0.707
end
2'b10:
begin
ar=32'b10111111001101010000010010000001; //-0.707
end
2'b11:
begin
end
endcase
end
endmodule
////////////////////////////////end of transmitter block///////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
////////////////////////////////channel////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
module channel(ar1,ai1,ar2,ai2,ar3,ai3,ar4,ai4,ar5,ai5,ar6,ai6,ar7,ai7,ar8,ai8,ar9,ai9,ar10,ai10,ar11,ai11,ar12,ai12,ar13,ai13,ar14,ai14,ar15,ai15,ar16,ai16,r1,r2,r3,r4,r5,r6,r7,r8,r9,r10,r11,r12,r13,r14,r15,r16,i1,i2,i3,i4,i5,i6,i7,i8,i9,i10,i11,i12,i13,i14,i15,i16);
//input clk;
input [31:0]ar1,ai1,ar2,ai2,ar3,ai3,ar4,ai4,ar5,ai5,ar6,ai6,ar7,ai7,ar8,ai8,ar9,ai9,ar10,ai10,ar11,ai11,ar12,ai12,ar13,ai13,ar14,ai14,ar15,ai15,ar16,ai16;
wire [31:0]h1r=32'b00111111000010011010011010110101; wire [31:0]h1i=32'b10111101111111100010100000100100;
wire [31:0]h2r=32'b00111111111010101011110100111100; wire [31:0]h2i=32'b00111111101111101010111001111101;
wire [31:0]h3r=32'b11000000000100001001000000101110; wire [31:0]h3i=32'b00111111101101000101101000011101;
wire [31:0]h4r=32'b00111111010111001011100100100100; wire [31:0]h4i=32'b00111111101101010110011011001111;
wire [31:0]h5r=32'b00111110101000110011100111000001; wire [31:0]h5i=32'b00111111001010111110011101101101;
wire [31:0]h6r=32'b10111111101001110110001010110111; wire [31:0]h6i=32'b10111111100110101000111101011100;
wire [31:0]h7r=32'b10111110110111100000000011010010; wire [31:0]h7i=32'b00111111001101111001101001101011;
wire [31:0]h8r=32'b00111110101011110110100101000100; wire [31:0]h8i=32'b00111111110100001010101001100101;
wire [31:0]h9r=32'b01000000011001010000010010000001; wire [31:0]h9i=32'b00111110111110100101000100011010;
wire [31:0]h10r=32'b01000000001100010011110111011001; wire [31:0]h10i=32'b00111111100001000111000100001101;
wire [31:0]h11r=32'b10111111101011001100100110000110; wire [31:0]h11i=32'b00111111001110100001011000011110;
wire [31:0]h12r=32'b01000000010000100011101111001101; wire [31:0]h12i=32'b10111110100110110101011100111111;
wire [31:0]h13r=32'b00111111001110011011001111010000; wire [31:0]h13i=32'b00111110100101100111101000010000;
wire [31:0]h14r=32'b10111101100000010011101010010011; wire [31:0]h14i=32'b10111111010010011000110001111110;
wire [31:0]h15r=32'b00111111001101101111011010010100; wire [31:0]h15i=32'b00111111011000110110111000101111;
wire [31:0]h16r=32'b10111110010100011110101110000101; wire [31:0]h16i=32'b10111111100100101101010000101100;
wire [31:0]nr1=32'b10111111100010001101000110110111; wire [31:0]ni1=32'b00111111100010111111000101000001;
wire [31:0]nr2=32'b10111111010011110011101101100100; wire [31:0]ni2=32'b00111111100011011111110110001011;
wire [31:0]nr3=32'b11000000001111000110111101101001; wire [31:0]ni3=32'b10111111010111010001101101110001;
wire [31:0]nr4=32'b00111111101110000001110101111110; wire [31:0]ni4=32'b00111101100111101000001111100100;
wire [31:0]nr5=32'b00111110101001101000000010011101; wire [31:0]ni5=32'b10111111100110110110011110100001;
wire [31:0]nr6=32'b10111111010000010100000100100000; wire [31:0]ni6=32'b10111111100011101000011100101011;
wire [31:0]nr7=32'b00111111101011110110010111111110; wire [31:0]ni7=32'b10111011110111101101001010001001;
wire [31:0]nr8=32'b10111111110110110001001001101111; wire [31:0]ni8=32'b00111111110001000010110000111101;
wire [31:0]nr9=32'b10111101110100010100111000111100; wire [31:0]ni9=32'b10111111010001010000101100001111;
wire [31:0]nr10=32'b10111110011101110011000110010000; wire [31:0]ni10=32'b00111110101111100010100000100100;
wire [31:0]nr11=32'b00111110101000110110111000101111; wire [31:0]ni11=32'b10111110011001110000001110110000;
wire [31:0]nr12=32'b00111110101000000011010001101110; wire [31:0]ni12=32'b00111111100011110000011011110111;
wire [31:0]nr13=32'b10111111010111010110101000010110; wire [31:0]ni13=32'b10111111100010110110011110100001;
wire [31:0]nr14=32'b10111100111101101001010001000110; wire [31:0]ni14=32'b00111101000001011000011110010100;
wire [31:0]nr15=32'b10111110001010001101101110001100; wire [31:0]ni15=32'b00111111000011010111000010100100;
wire [31:0]nr16=32'b00111111001000001011000011110010; wire [31:0]ni16=32'b00111111100011001110000001110110;
output [31:0]r1,r2,r3,r4,r5,r6,r7,r8,r9,r10,r11,r12,r13,r14,r15,r16;
output [31:0]i1,i2,i3,i4,i5,i6,i7,i8,i9,i10,i11,i12,i13,i14,i15,i16;
trans t1(ar1,ai1,h1r,h1i,nr1,ni1,r1,i1);
trans t2(ar2,ai2,h2r,h2i,nr2,ni2,r2,i2);
trans t3(ar3,ai3,h3r,h3i,nr3,ni3,r3,i3);
trans t4(ar4,ai4,h4r,h4i,nr4,ni4,r4,i4);
trans t5(ar5,ai5,h5r,h5i,nr5,ni5,r5,i5);
trans t6(ar6,ai6,h6r,h6i,nr6,ni6,r6,i6);
trans t7(ar7,ai7,h7r,h7i,nr7,ni7,r7,i7);
trans t8(ar8,ai8,h8r,h8i,nr8,ni8,r8,i8);
trans t9(ar9,ai9,h9r,h9i,nr9,ni9,r9,i9);
trans t10(ar10,ai10,h10r,h10i,nr10,ni10,r10,i10);
trans t11(ar11,ai11,h11r,h11i,nr11,ni11,r11,i11);
trans t12(ar12,ai12,h12r,h12i,nr12,ni12,r12,i12);
trans t13(ar13,ai13,h13r,h13i,nr13,ni13,r13,i13);
trans t14(ar14,ai14,h14r,h14i,nr14,ni14,r14,i14);
trans t15(ar15,ai15,h15r,h15i,nr15,ni15,r15,i15);
trans t16(ar16,ai16,h16r,h16i,nr16,ni16,r16,i16);
endmodule
module trans(af,bf,cf,df,nr,ni,out_real,out_imag);
input [31:0]af,bf;//transmitted values
input [31:0]cf,df;//channel co-effiecients
input [31:0]nr,ni;
wire [31:0]noise_r,noise_i;
output [31:0]out_real,out_imag;
wire [31:0]x1,x2,x,y,z,r1,r2,i1;
//noise variance
parameter [31:0]var=32'b00000000000000000000000000000000; // no noise (ideal ccase)
//parameter [31:0]var=32'b00111101110011001100110011001101 ; //var=0.1
//parameter [31:0]var=32'b00111111100000000000000000000000 ;//var=1
//parameter [31:0]var=32'b01000001001000000000000000000000 ;//var=10
//parameter [31:0]var=32'b01000001111111001111100111011011; //var=31.622
fpmul m1(nr,var,noise_r);
fpmul m2(ni,var,noise_i);
fpadd a1(af,bf,x1); //complex multiplication
fpadd a2(cf,{~df[31],df[30:0]},x2);
fpmul m3(x1,x2,x);
fpmul m4(bf,cf,y);
fpmul m5(af,df,z);
fpadd a3(y,{~z[31],z[30:0]},r1);
fpadd a4(x,{~r1[31],r1[30:0]},r2);
fpadd a5(r2,noise_r,out_real);
fpadd a6(y,z,i1);
fpadd a7(i1,noise_i,out_imag);
endmodule
////////////////////////////////////////////receiver block///////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
//precomputation of data words and multiplying it with the results obtained from the receiver
module rec(clk,r1,r2,r3,r4,r5,r6,r7,r8,r9,r10,r11,r12,r13,r14,r15,r16,i1,i2,i3,i4,i5,i6,i7,i8,i9,i10,i11,i12,i13,i14,i15,i16,wout,xout,yout,zout);
input clk;
input [31:0]r1,r2,r3,r4,r5,r6,r7,r8,r9,r10,r11,r12,r13,r14,r15,r16,i1,i2,i3,i4,i5,i6,i7,i8,i9,i10,i11,i12,i13,i14,i15,i16;
reg [31:0] data_1 [1:16];
reg [31:0] data_2 [1:16];
reg [31:0] data_3 [1:16];
reg [31:0] data_4 [1:16];
wire [31:0]yr1,yr2,yr3,yr4,yr5,yr6,yr7,yr8,yr9,yr10,yr11,yr12,yr13,yr14,yr15,yr16;
wire [31:0]yi1,yi2,yi3,yi4,yi5,yi6,yi7,yi8,yi9,yi10,yi11,yi12,yi13,yi14,yi15,yi16;
wire [31:0]rww1,rww2,rww3,rww4,rww5,rww6,rww7,rww8,rww9,rww10,rww11,rww12,rww13,rww14,rww15,rww16;
wire [31:0]rxx1,rxx2,rxx3,rxx4,rxx5,rxx6,rxx7,rxx8,rxx9,rxx10,rxx11,rxx12,rxx13,rxx14,rxx15,rxx16;
wire [31:0]ryy1,ryy2,ryy3,ryy4,ryy5,ryy6,ryy7,ryy8,ryy9,ryy10,ryy11,ryy12,ryy13,ryy14,ryy15,ryy16;
wire [31:0]rzz1,rzz2,rzz3,rzz4,rzz5,rzz6,rzz7,rzz8,rzz9,rzz10,rzz11,rzz12,rzz13,rzz14,rzz15,rzz16;
output [31:0]wout,xout,yout,zout;
//known h parameter of channel estimation (no error - ideal)
wire [31:0]h1r=32'b00111111000010011010011010110101; wire [31:0]h1i=32'b00111101111111100010100000100100;
wire [31:0]h2r=32'b00111111111010101011110100111100; wire [31:0]h2i=32'b10111111101111101010111001111101;
wire [31:0]h3r=32'b11000000000100001001000000101110; wire [31:0]h3i=32'b10111111101101000101101000011101;
wire [31:0]h4r=32'b00111111010111001011100100100100; wire [31:0]h4i=32'b10111111101101010110011011001111;
wire [31:0]h5r=32'b00111110101000110011100111000001; wire [31:0]h5i=32'b10111111001010111110011101101101;
wire [31:0]h6r=32'b10111111101001110110001010110111; wire [31:0]h6i=32'b00111111100110101000111101011100;
wire [31:0]h7r=32'b10111110110111100000000011010010; wire [31:0]h7i=32'b10111111001101111001101001101011;
wire [31:0]h8r=32'b00111110101011110110100101000100; wire [31:0]h8i=32'b10111111110100001010101001100101;
wire [31:0]h9r=32'b01000000011001010000010010000001; wire [31:0]h9i=32'b10111110111110100101000100011010;
wire [31:0]h10r=32'b01000000001100010011110111011001; wire [31:0]h10i=32'b10111111100001000111000100001101;
wire [31:0]h11r=32'b10111111101011001100100110000110; wire [31:0]h11i=32'b10111111001110100001011000011110;
wire [31:0]h12r=32'b01000000010000100011101111001101; wire [31:0]h12i=32'b00111110100110110101011100111111;
wire [31:0]h13r=32'b00111111001110011011001111010000; wire [31:0]h13i=32'b10111110100101100111101000010000;
wire [31:0]h14r=32'b10111101100000010011101010010011; wire [31:0]h14i=32'b00111111010010011000110001111110;
wire [31:0]h15r=32'b00111111001101101111011010010100; wire [31:0]h15i=32'b10111111011000110110111000101111;
wire [31:0]h16r=32'b10111110010100011110101110000101; wire [31:0]h16i=32'b00111111100100101101010000101100;
wire [31:0]h1ic={~h1i[31],h1i[30:0]};
wire [31:0]h2ic={~h2i[31],h2i[30:0]};
wire [31:0]h3ic={~h3i[31],h3i[30:0]};
wire [31:0]h4ic={~h4i[31],h4i[30:0]};
wire [31:0]h5ic={~h5i[31],h5i[30:0]};
wire [31:0]h6ic={~h6i[31],h6i[30:0]};
wire [31:0]h7ic={~h7i[31],h7i[30:0]};
wire [31:0]h8ic={~h8i[31],h8i[30:0]};
wire [31:0]h9ic={~h9i[31],h9i[30:0]};
wire [31:0]h10ic={~h10i[31],h10i[30:0]};
wire [31:0]h11ic={~h11i[31],h11i[30:0]};
wire [31:0]h12ic={~h12i[31],h12i[30:0]};
wire [31:0]h13ic={~h13i[31],h13i[30:0]};
wire [31:0]h14ic={~h14i[31],h14i[30:0]};
wire [31:0]h15ic={~h15i[31],h15i[30:0]};
wire [31:0]h16ic={~h16i[31],h16i[30:0]};
transRX t1(r1,i1,h1r,h1ic,yr1,yi1);
transRX t2(r2,i2,h2r,h2ic,yr2,yi2);
transRX t3(r3,i3,h3r,h3ic,yr3,yi3);
transRX t4(r4,i4,h4r,h4ic,yr4,yi4);
transRX t5(r5,i5,h5r,h5ic,yr5,yi5);
transRX t6(r6,i6,h6r,h6ic,yr6,yi6);
transRX t7(r7,i7,h7r,h7ic,yr7,yi7);
transRX t8(r8,i8,h8r,h8ic,yr8,yi8);
transRX t9(r9,i9,h9r,h9ic,yr9,yi9);
transRX t10(r10,i10,h10r,h10ic,yr10,yi10);
transRX t11(r11,i11,h11r,h11ic,yr11,yi11);
transRX t12(r12,i12,h12r,h12ic,yr12,yi12);
transRX t13(r13,i13,h13r,h13ic,yr13,yi13);
transRX t14(r14,i14,h14r,h14ic,yr14,yi14);
transRX t15(r15,i15,h15r,h15ic,yr15,yi15);
transRX t16(r16,i16,h16r,h16ic,yr16,yi16);
initial
begin
$readmemb("RPB1-realoutput.txt", data_1);
$readmemb("RPB2-realoutput.txt", data_2);
$readmemb("RPB3-realoutput.txt", data_3);
$readmemb("RPB4-realoutput.txt", data_4);
end
assign rww1=data_1[1];
assign rww2=data_1[2];
assign rww3=data_1[3];
assign rww4=data_1[4];
assign rww5=data_1[5];
assign rww6=data_1[6];
assign rww7=data_1[7];
assign rww8=data_1[8];
assign rww9=data_1[9];
assign rww10=data_1[10];
assign rww11=data_1[11];
assign rww12=data_1[12];
assign rww13=data_1[13];
assign rww14=data_1[14];
assign rww15=data_1[15];
assign rww16=data_1[16];
assign rxx1=data_2[1];
assign rxx2=data_2[2];
assign rxx3=data_2[3];
assign rxx4=data_2[4];
assign rxx5=data_2[5];
assign rxx6=data_2[6];
assign rxx7=data_2[7];
assign rxx8=data_2[8];
assign rxx9=data_2[9];
assign rxx10=data_2[10];
assign rxx11=data_2[11];
assign rxx12=data_2[12];
assign rxx13=data_2[13];
assign rxx14=data_2[14];
assign rxx15=data_2[15];
assign rxx16=data_2[16];
assign ryy1=data_3[1];
assign ryy2=data_3[2];
assign ryy3=data_3[3];
assign ryy4=data_3[4];
assign ryy5=data_3[5];
assign ryy6=data_3[6];
assign ryy7=data_3[7];
assign ryy8=data_3[8];
assign ryy9=data_3[9];
assign ryy10=data_3[10];
assign ryy11=data_3[11];
assign ryy12=data_3[12];
assign ryy13=data_3[13];
assign ryy14=data_3[14];
assign ryy15=data_3[15];
assign ryy16=data_3[16];
assign rzz1=data_4[1];
assign rzz2=data_4[2];
assign rzz3=data_4[3];
assign rzz4=data_4[4];
assign rzz5=data_4[5];
assign rzz6=data_4[6];
assign rzz7=data_4[7];
assign rzz8=data_4[8];
assign rzz9=data_4[9];
assign rzz10=data_4[10];
assign rzz11=data_4[11];
assign rzz12=data_4[12];
assign rzz13=data_4[13];
assign rzz14=data_4[14];
assign rzz15=data_4[15];
assign rzz16=data_4[16];
sumofproducts A1(rww1,rww2,rww3,rww4,rww5,rww6,rww7,rww8,rww9,rww10,rww11,rww12,rww13,rww14,rww15,rww16,wout);
sumofproducts A2(rxx1,rxx2,rxx3,rxx4,rxx5,rxx6,rxx7,rxx8,rxx9,rxx10,rxx11,rxx12,rxx13,rxx14,rxx15,rxx16,xout);
sumofproducts A3(ryy1,ryy2,ryy3,ryy4,ryy5,ryy6,ryy7,ryy8,ryy9,ryy10,ryy11,ryy12,ryy13,ryy14,ryy15,ryy16,yout);
sumofproducts A4(rzz1,rzz2,rzz3,rzz4,rzz5,rzz6,rzz7,rzz8,rzz9,rzz10,rzz11,rzz12,rzz13,rzz14,rzz15,rzz16,zout);
endmodule
module transRX(af,bf,cf,df,out_real,out_imag); //complex multiplication submodule
input [31:0]af,bf;//received sigals
input [31:0]cf,df;//conjugate channel co-effiecients
fpadd a1(af,bf,x1);
fpmul m3(x1,x2,x);
fpmul m4(bf,cf,y);
fpmul m5(af,df,z);
fpadd a4(x,{~r1[31],r1[30:0]},out_real);
fpadd a6(y,z,out_imag);
endmodule
module sumofproducts(rw1s,rw2s,rw3s,rw4s,rw5s,rw6s,rw7s,rw8s,rw9s,rw10s,rw11s,rw12s,rw13s,rw14s,rw15s,rw16s,wout);
input[31:0]rw1s,rw2s,rw3s,rw4s,rw5s,rw6s,rw7s,rw8s,rw9s,rw10s,rw11s,rw12s,rw13s,rw14s,rw15s,rw16s;
output [31:0]wout;
wire [31:0]w1s,w2s,w3s,w4s,w5s,w6s,w7s,w8s,w9s,w10s,w11s,w12s,w13s,w14s,w15s,w16s;
wire [31:0]wout1,wout2,wout3,wout4,wout5,wout6,wout7,wout8;
wire [31:0]wout11,wout22,wout33,wout44;
wire [31:0]wout111,wout222;
fpadd a17(rw1s,rw2s,wout1);
fpadd a18(rw3s,rw4s,wout2);
fpadd a19(rw5s,rw6s,wout3);
fpadd a20(rw7s,rw8s,wout4);
fpadd a21(rw9s,rw10s,wout5);
fpadd a22(rw11s,rw12s,wout6);
fpadd a23(rw13s,rw14s,wout7);
fpadd a24(rw15s,rw16s,wout8);
fpadd a25(wout1,wout2,wout11);
fpadd a26(wout3,wout4,wout22);
fpadd a27(wout5,wout6,wout33);
fpadd a28(wout7,wout8,wout44);
fpadd a29(wout11,wout22,wout111);
fpadd a30(wout33,wout44,wout222);
fpadd a31(wout111,wout222,wout);
endmodule
module compare(wout,xout,yout,zout,detected_data);
input [31:0]wout,xout,yout,zout;
output reg [31:0]detected_data;
reg [31:0]CFItemp1,CFItemp2;
reg [31:0]temp1,temp2,temp3;
always @ (wout,xout,yout,zout)
begin
if(wout[31] == 0 && xout[31]== 0)
begin
if(wout[30:23]>xout[30:23])
begin
temp1=wout;
CFItemp1=32'b01101101101101101101101101101101;
end
else if(wout[30:23]<xout[30:23])
begin
temp1=xout;
CFItemp1=32'b10110110110110110110110110110110;
end
else
begin
if (wout[22:0]>xout[22:0])
begin
temp1=wout;
end
else
begin
temp1=xout;
end
end
end
else if (wout[31]==1 && xout[31]==0)
begin
begin
temp1=xout;
end
begin
temp1=xout;
end
else
begin
begin
temp1=xout;
end
else
begin
temp1=wout;
end
end
end
else if(wout[31]==0 && xout[31]==1)
begin
begin
temp1=wout;
end
begin
temp1=wout;
end
else
begin
begin
temp1=wout;
end
else
begin
temp1=xout;
end
end
end
else if(wout[31]==1 && xout[31]==1)
begin
begin
temp1=wout;
end
else if(wout[30:23]>xout[30:23])
begin
temp1=xout;
end
else
begin
if (wout[22:0]<xout[22:0])
begin
temp1=wout;
end
else
begin
temp1=xout;
end
end
end
if(yout[31] == 0 && zout[31]== 0)
begin
if(yout[30:23]>zout[30:23])
begin
temp2=yout;
CFItemp2=32'b11011011011011011011011011011011;
end
else if(yout[30:23]<zout[30:23])
begin
temp2=zout;
CFItemp2=32'b00000000000000000000000000000000;
end
else
begin
if (yout[22:0]>zout[22:0])
begin
temp2=yout;
end
else
begin
temp2=zout;
end
end
end
else if (yout[31]==1 && zout[31]==0)
begin
begin
temp2=zout;
end
begin
temp2=zout;
end
else
begin
begin
temp2=zout;
end
else
begin
temp2=yout;
end
end
end
else if(yout[31]==0 && zout[31]==1)
begin
begin
temp2=yout;
end
begin
temp2=yout;
end
else
begin
begin
temp2=yout;
end
else
begin
temp2=zout;
end
end
end
else if(yout[31]==1 && zout[31]==1)
begin
begin
temp2=yout;
end
else if(yout[30:23]>zout[30:23])
begin
temp2=zout;
end
else
begin
if (yout[22:0]<zout[22:0])
begin
temp2=yout;
end
else
begin
temp2=zout;
end
end
end
if(temp1[31] == 0 && temp2[31]== 0)
begin
if(temp1[30:23]>temp2[30:23])
begin
temp3=temp1;
detected_data=CFItemp1;//2'b01;
end
else if(temp1[30:23]<temp2[30:23])
begin
temp3=temp2;
detected_data=CFItemp2;//2'b10;
end
else
begin
if (temp1[22:0]>temp2[22:0])
begin
temp3=temp1;
end
else
begin
temp3=temp2;
end
end
end
else if (temp1[31]==1 && temp2[31]==0)
begin
begin
temp3=temp2;
end
begin
temp3=temp2;
end
else
begin
begin
temp3=temp2;
end
else
begin
temp3=temp1;
end
end
end
else if(temp1[31]==0 && temp2[31]==1)
begin
begin
temp3=temp1;
end
begin
temp3=temp1;
end
else
begin
begin
temp3=temp1;
end
else
begin
temp3=temp2;
end
end
end
else if(temp1[31]==1 && temp2[31]==1)
begin
begin
temp3=temp1;
end
else if(temp1[30:23]>temp2[30:23])
begin
temp3=temp2;
end
else
begin
if (temp1[22:0]<temp2[22:0])
begin
temp3=temp1;
end
else
begin
temp3=temp2;
end
end
end
end
endmodule
//floating point adder
module fpadd(a,b,out);
input [31:0]a,b;
output [31:0]out;
wire [7:0]e1,e2,ex,ey,exy,ex1,ey1,ex2,ex3;
wire s1,s2,s,s3,sr,sn,s4,sx1,sy1,sn1,sn2,sn3,sn4,sr1,sr2,sn5,sn6;
wire [23:0]m1,m2,mx,my,mxy,mx1,my1;
wire [24:0]mxy1,mxy2;
assign s1=a[31];
assign s2=b[31];
assign e1=a[30:23];
assign e2=b[30:23];
assign m1[23]=1'b1;
assign m2[23]=1'b1;
assign m1[22:0]=a[22:0];
assign m2[22:0]=b[22:0];
//submodule for compare and shfit
cmpshift as(e1[7:0],e2[7:0],s1,s2,m1[23:0],m2[23:0],clk,ex,ey,mx,my,s,sx1,sy1);
//submodule for mantissa addition snd subtraction
faddsub as1(mx,my,sx1,sy1,s,ex,clk,mxy1,ex2,sn3,sn4,s3,sr1);
//sub module for normalization
normalized as2(mxy1,sr1,sn3,sn4,s3,clk,ex,sr,exy,mxy);
assign out={sr,exy,mxy[22:0]};
endmodule
module normalized(mxy1,s,s1,s2,s3,clk,ex,sr,exy,mxy);
input[24:0]mxy1;
input s,s1,s2,s3,clk;
input[7:0]ex;
output reg sr;
output reg[7:0]exy;
output reg[23:0]mxy;
reg [24:0]mxy2;
always@(*)
begin
sr=s?s1^(mxy1[24]&s3):s2^(mxy1[24]&s3);
mxy2=(mxy1[24]&s3)?~mxy1+25'b1:mxy1;
mxy=mxy2[24:1];
exy=ex;
repeat(24)
begin
if(mxy[23]==1'b0)
begin
mxy=mxy<<1'b1;
exy=exy-8'b1;
end
end
end
endmodule
//submodule for addition or subtraction
module faddsub(a,b,s1,s2,sn,ex1,clk,out,ex2,sn3,sn4,s,sr1);
input [23:0]a,b;
input[7:0]ex1;
input s1,s2,clk,sn;
output reg [7:0]ex2;
output reg[24:0]out;
output reg s,sn3,sn4,sr1;
always@(*)
begin
ex2=ex1;
sr1=sn;
sn3=s1;
sn4=s2;
s=s1^s2;
if(s)
begin
out=a-b;
end
else
begin
out=a+b;
end
end
endmodule
//module for copare &shift
module cmpshift(e1,e2,s1,s2,m1,m2,clk,ex,ey,mx,my,s,sx1,sy1);
input [7:0]e1,e2;
input [23:0]m1,m2;
input clk,s1,s2;
output reg[7:0]ex,ey;
output reg[23:0]mx,my;
output reg s,sx1,sy1;
reg [7:0]diff;
always@(*)
begin
sx1=s1;
sy1=s2;
if(e1==e2)
begin
ex=e1+8'b1;
ey=e2+8'b1;
mx=m1;
my=m2;
s=1'b1;
end
else if(e1>e2)
begin
diff=e1-e2;
ex=e1+8'b1;
ey=e1+8'b1;
mx=m1;
my=m2>>diff;
s=1'b1;
end
else
begin
diff=e2-e1;
ex=e2+8'b1;
ey=e2+8'b1;
mx=m2;
my=m1>>diff;
s=1'b0;
end
end
endmodule
//floating point multiplier
module fpmul(a,b,out);
input[31:0]a,b;
output [31:0]out;
wire [7:0]exp;
wire [22:0]mant;
wire s;
fmul manipulate(a[30:23],b[30:23],a[31],b[31],{1'b1,a[22:0]},{1'b1,b[22:0]},exp,mant,s);
assign out={s,exp,mant}; //concatenation
endmodule
//submodule for multiplication
module fmul(aexp,bexp,as,bs,am,bm,exp,mant,s);
input [23:0]am,bm;
input[7:0]aexp,bexp;
input as,bs;
output reg [7:0]exp;
output reg[22:0]mant;
output reg s;
reg flag; //zero flag
reg [7:0]ex;
reg [8:0]e;
reg [47:0]man;
always@(*)
begin
if(((aexp==0)||(bexp==0))&&((am[22:0]==0)||(bm[22:0]==0))) //check for zero operand
begin
exp=0;
mant=0;
s=0;
flag=1;
end
else
begin
s=as^bs; //sign
e=aexp+bexp; //exponent
ex=e-127;
man=am*bm; //mantissa
flag=0;
end
//normalise
if(~flag)
if(man[47]==0)
begin
mant=man[45:23]; //truncate and have only 23 bits from MSB
exp=ex;
end
else
begin
mant=man[46:24];
exp=ex+1;
end
end
endmodule
