timing diagram to HDL conversion
FixitFast
Junior Member level 2
Dear all,
I have done HDL writing using flow diagram but I am not to program using Timing Diagram from some memory interface.
Can I know what is the best way to do that. I Guess if I simply follow the timing diagram for, lets say one operation, and write code accordingly for
x,y, z signals, then it might violate things for other signals or processes...
What is the proper method.
Waiting for response
Bests,
Usually, read the timing diagram.
write the code
write a testbench. Test.
program chip - test again.
Its up to you to know if theres a problem. Sometimes manufacturerrs may provide an HDL simulation model of their chip. use that in your testbench to help verify the code you've written wont break anything.
