Time Dependent Signals
prakhars
Junior Member level 3
I wanted to know, what is the actual practical significance of having an time shifted signal.
i.e meaning of x(t-5) or x(t+6) in practical. and where can i see the effect of time shifted signals.
and also if a signal has a fixed frequency configuration then why its Fourier Transform differs when taken for a time shifted version.
i.e FT of x(t), is not as same as FT of x(t-5) although x(t-5) is the same signal as x(t), simply shifted in time ,....
when a signal is shifted in time it means the start time of signal is changed,and i don't think it's sth hard to be figured out
and for F transform when a signal is shifted the harmonics are the same and does not differ instead of the exponatioal coeficient which indicates the start time of signal
hope this helps
Time shifted signals are very important in the analysis of LTI (linear time invariant) systems and in DSP. Usually you can decompose a complicated signal into basic time shifted signals. And analyze each signal and then apply superposition. For example a rectangular pulse can be represented by two shifted unit steps.
Time shifted impulses are very important in DSP. Because discrete signal can be represented by a sum of time shifted weighted unit impulses.
The time shift property of the FT is F{x(t-a)} = X(jw) e^(-a jw) . Means that a shift in time corresponds to just a change in phase in the FT.
one example might be "multi-path" in RF communications. In this case, the transmitter and receiver may not have a line-of-sight, but the signal may reflect off of several objects. It is possible that several paths are possible, and that only a few are really dominant.
A second example might be radar/sonar, where a pulse is sent out and a reflection of the pulse is measured later.
