panalog9
Full Member level 2
pulsonix symbols
Hi All -
I've been playing around a little with Puls0nix for a few days now, and it really does look good. I'm usually a Pr0tel 99SE user, and have found that the new DXP2004 really looks nice, and has a few very good new features, but on the whole, it takes longer to do things. So I'm looking around at other packages. Puls0nix, C@dstar, P@DS 2004.
Puls0nix has a very nicely done library system. There are schematic symbols, footprints, schematic doc symbols and pcb doc symbols. On top of that is the "Part", which links the symbols together.
You can define a part to have several sch symbols if you want, but more importantly it can define several footprints. The Part system lets you map the sch symbol pins for each footprint differently. For example, a micro with 5 ADC channels in DIP format and 8 ADC channels in SOIC format can both use the same sch symbol.
You can also create 0-pin parts, like bolts, nuts, washers etc. These can be associated with a part or with a footprint. So a 7805 regulator in to92 footprint has nothing, while the TO220 footprint has a screw, washer and nut associated with it. It's nice to be able to associate the box/enclosure part to the design without the kluges needed with Pr0tel.
The default colors suck. Maybe I'm just more attuned to 99SE. Easy enough to change. Drawing arcs is cumbersome - 99SE is much nicer. No easy way to do radial placement of parts. There are a few other annoying things, but thay may just be me being set in my ways.
Anyone else looked at Puls0nix in any detail ? What thoughts and opinions do you have ?
-pana
Hi All -
-pana
