[SOLVED] Thermocouple signal amplification using INA126P
ponnus
Full Member level 2
Full Member level 2
Cochin, INDIA
Hai,
I'm trying to interface a thermocouple to microcontroller. As the thermocouple produces very low voltage, I've given an INA126P instrumentation amplifier to amplify the voltage. I'm using +5V as V+ and GND as V- and Vref=2.5V.
But, in the datasheet it says input common mode voltage is 1.5V to 3.5V (from graph). So, I tried to add an offset to the thermocouple input.
I've done that in two ways:1)Using an Op-amp and 2)Using a voltage divider.
here is my schematic........
1)Using voltage divider......
2)Using Opamp.....
Sorry, it's hand drawn....
May I know my circuit is correct?
Thank you
The OP circuit will kill INA126 offset performance. The voltage divider circuit is O.K., except for the 100 nF output load, which won't be accepted by INA126.
Reactions: ponnus
    ponnus
Hai,
Thank you for the reply.
I've replaced the voltage divider with TL431 2.5V reference source and tested the circuit by taking thermocouple readings.
Now, I like to set Vref of INA126 as 1.2V.
Is it ok, if I use a voltage divider or 1.2V zener as Vref?
Thank you
