[General] Thermal Printer interfacing with PIC
Raees
Junior Member level 2
Kindly Identify the printer. and provide document details. I need to interface it with PIC microcontroller. If any one has an idea, kindly share it.
Thanks
google for "WH-E23 thermoprinter"
isn´t that a lot of information? What else do you need?
Klaus
it depends on protocol and communication commands.
Maybe here is a specialist knowing exactely this printer....
But i´d look at the manufacturer´s web pages, or directely ask the manufacturer.
Klaus
hello,
Compatible with ESC/POS command set, more characters style setting commands
Serial(RS-232C ) interface
maybe these old document can help you.. ESC command for printer
just try to send direct command with a RS232 terminal to the printer
like VBRAY terminal , easy to send ESC sequence of char
with programmable key or script.
I have tried sending commands by RS-232. but its not working.
I am working on PIC16f877a. Using CCS Compiler.
I am sending data like:
printf("1111111111"); //Data to be printed on paper.
putc(13); //CR decimal code. print command
Its not working. After sending "CR" command 20 to 25 times, It prints one line in chinese.
Plz help.. can some provide example-code of few line to print simply "hello world".
