andrei_electronics
Newbie level 3
Hello,
I need to choose from the market a thermal cutoff to connect it close to a TVS diode, so if the TVS goes too hot, the thermal cutoff interrupts the circuit.
I have to mention that in series with this thermal cutoff it is already a melting fuse and the TVS diode (1.5KE33CA) withstand to peak power pulse up to 1500W. The melting fuse is chosen so its time to trip is shorter than the maximum time allowed for the TVS to withstand peak power up to 1500W.
But in case there is an over voltage around the breaking voltage of TVS, the current will be low and the time to trip of the melting fuse will be longer. This low current, even if it's low (I don't have a specific value) it may heat the TVS diode so after some time it will break the TVS.
Now my concern is how to choose the thermal cutoff, how to choose the temperature for it?
Can you help me with some ways to calculate this temperature for the appropriate thermal cutoff?
Thank you!
Thank you!
