The way to test IC AD71056?
binhbk
Newbie level 3
Hi all,
I'm using the IC AD71056 to measure the electrical energy. But this IC is died easily. Please help to to know the way to test it before i use it into my circuit.
Thanks!
what is the power supply you are using i mean how much voltage to Vdd you given?
show your circuit or schematic to help you better
Reactions: binhbk
    binhbk
Here, I only want to know the method testing this IC before I use it, before i put it into my circuit. It is not depend on my circuit
just read the datasheet it has it's application or test circuit and many other useful information you need.
Reactions: binhbk
    binhbk
Thanks for your comment
To test the performance limits of this chip in a fair environment, you need an EVAL BOARD kit or your own test circuit board to properly test it.
Analog Devices has free test software for ADC chips, but I always liked the simplicity method of using a DAC with a ADC to perform closed loop A-B tests using a scope for monoticity, noise, missing code and non-linearity tests.
Reactions: binhbk
    binhbk
