the way to generate register
skycanny
Junior Member level 3
hi,all guys. Is there any way to generate regisers in CPLD or FPGA except using "signal" and "DFF" instantiation?
Any help would be appreciated!
What is wrong woith using "signal", or what are trying to impliment?
You might be able to instantiate the vendors RAM in the device directly.
well...u can make a register urself,
see this code:
library ieee ;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity reg is
generic(n: natural :=2);
port( I: in std_logic_vector(n-1 downto 0);
clock: in std_logic;
load: in std_logic;
clear: in std_logic;
Q: out std_logic_vector(n-1 downto 0)
end reg;
architecture behv of reg is
signal Q_tmp: std_logic_vector(n-1 downto 0);
begin
process(I, clock, load, clear)
begin
if clear = '0' then
-- use 'range in signal assigment
Q_tmp <= (Q_tmp'range => '0');
elsif (clock='1' and clock'event) then
if load = '1' then
Q_tmp <= I;
end if;
end if;
end process;
-- concurrent statement
Q <= Q_tmp;
end behv;
(u can change it according to ur needs, u don't have to have all these inputs for instance, i hope that is what u want)
best regards,
Salma:D
This is the version in verilog, FYI:
reg Q;
always @ ( negedge Rst_n or posedge Clk ) begin
if( !Rst_n )
Q <= 1'b0;
else if( En )
Q <= D_In;
end
Michael Zhang
Your Ideal Prototyping PCB service:
Hi ur answer helpful me too . ple tell me how to instantiate the vendors RAM in the device directly?
In the name of God
a non-recomended way of register generation is using asynchronous method.plz don't use this method,althought it is described in brown and veransic digital logic text book.
regards
