The unity gain amplifiers in differential charge pumps
shadoweek
Member level 2
Member level 2
charge pumps question
hi
i have a simple question in charge pumps:
what is the role of the unity gain amplifiers when using differential charge pumps?
Re: charge pumps question
hello,
i think that they r used to decrease the dynamics and charge sharing (i.e. when the up signal change the voltage of the drain of the MOS with UP-bar have the sdame voltage as the drain of the MOS with UP , so the current will move smoth and no dynamics is formed )
note i am really just guessing .
a.safwat
    shadoweek
Check this Architecture there is no unity gain amplifiers
    shadoweek
Yea its to mitigate charge sharing problem between the drain of PMOS, NMOS and loop filter. Basically it fixes the drain voltage so that the drain voltage does not pull to gnd or Vdd when the switch is off.
    shadoweek
