[SOLVED] The open loop DC gain
m_kuty
Hello everyone
Can any one help me in the Figure bellow,
1. Why are there capacitor (0.1u) and resistor (10M) in the circuit of the open loop response?
2. what the reason of there capacitor and resistor ?
3.what is the called this circuit?
4. and why the non-inverting feeding VDD/2?
The resistor provides DC negative feedback with a DC gain of 1.
This biases the op amp so the output doesn't saturate.
The capacitor prevents the source from connecting the input do DC ground and upsetting the bias.
The RC time constant is sufficiently long so that the test can go below 10Hz, where the op amp reaches its DC gain value
The circuit is called an op amp open-loop gain test circuit.
It actually tests the AC gain down to a very low frequency.
The VDD/2 connection is so that op amp input and output are biased at 1/2 the supply voltage (because of the non-inverting gain of 1), not at ground where standard op amps don't work.
The test circuit is flawed respectively isn't suited to measure the open loop frequency response. To achieve the plotted frequency response, the capacitor must have a factor 1e6 higher value.
Curiously the circuit can be found in the LM358/LM324 data sheet since more than 40 years.
Reactions: m_kuty
    m_kuty
Good catch.
Yes, the impedance of the capacitor at the lowest test frequency must be less than the feedback resistance divided by the open-loop gain.
This requires a capacitor in the neighborhood of a farad for the feedback resistance and open-loop gain shown.
Reactions: m_kuty
    m_kuty
I´m not sure bout this.
The capacitor and the feedback resistor forms a differentiator circuit. (not a high pass filter with a -3dB corner frequency)
It has low gain with low frequencies and high gain at high frequencies.
This may be used to compensate for the first order low pass filter characteristic of the OPAMP.
The benefit is that the output voltage dynamic is not that big as without the differentiator circuit. During the whole bandwidth of the first order section the output voltage should be constant.
But indeed the circuit is not useful to measure DC gain. Additionally this is feedbacked circuit and not an open loop circuit.
As said: I´m not sure.
Reactions: m_kuty
    m_kuty
Thank you everyone and who has been contributed to answer my questions.
is there any disadvantages for using this particular circuit.
I need more about the Vdd/2 on non-inverting. more expansions
To measure the DC gain in the open loop for this circuit is the output node and the node between the resistor and capacitor.
Here's an LTspice simulation of the circuit with capacitor values of 0.1µf and 1f.
As Klauss noted, the capacitor acts as a differentiator, but that's only until the differentiator gain reaches the open loop gain of the op amp
For the 0.1µf cap, this occurs at about 400Hz (green trace).
After that, and the resonant peak, it follows the open-loop gain versus frequency curve.
The 1f capacitor value has a differentiator gain equal to the open loop gain at below 0.1Hz, so the output follows the open-loop gain all the way (yellow trace).
Reactions: m_kuty
    m_kuty
