irun2
Member level 2
Hi there!
This is a mcu design and not very large scale. I've encountered a problem when doing synthesis work.
No matter what I try, like using -incremental and -map high options, the Max transision violation stays there!
max_transition
Required Actual
Net Transition Transition Slack
mcu_otp/RegRdAddr[0] (dont_touch)
4.50 15.24 -10.74 (VIOLATED)
max_capacitance
Required Actual
Net Capacitance Capacitance Slack
0.16 0.65 -0.50 (VIOLATED)
report_net report below statistics:
Attributes:
dr - drc disabled
c - annotated capacitance
d - dont_touch
i - ideal_net
I - ideal_network
p - includes pin load
r - annotated resistance
h - high fanout
Net Fanout Attributes Capacitance Driver
65 d 0.65 mcu_otp/pwd1/decode/U144/Y
I've tried remove_attribute mcu_otp/RegRdAddr[0] dont_touch and compile again, but without luck.
How can I get rid of those violations like capacitance and transition? Should I manually add buffer to that pin? Or leave it to P&R guys?
max_transition
Required Actual
max_capacitance
Required Actual
Attributes:
dr - drc disabled
d - dont_touch
i - ideal_net
I - ideal_network
h - high fanout
