Refer fig.23 of this tech note from Maxim, showing the application of 485 IC as a repeater. You have to ground REbar and pull up DE in this case.
Regards, Laktronics
Hello FVM,
I think these repeaters have limitations and are meant for 4wire RS-485 or 422(one-on-one)applications only. For RS-485 applications having single master and multiple slaves, the circuit will work if all slaves are located beyond the repeater with respect to Master. If some of the slaves are located between the master and the repeater, those slaves beyond the repeater should generate a repeater enable signal while transmitting data to the Master.
Multi Master RS485 should also work so long as all masters are located on one side of the repeater.
Regards, Laktronics
For two wire circuits, this repeater can be used with automatic direction switching for a given baud rate. But again this circuit has a limitation in that the RC time values will change for each baud rate and a DIP switch selection will be required to select different RC values for different baud rates. Another variation of this circuit replacing the flip-flop circuit with retriggerable monshots like HC123 will have better timing control than passive RC connection shown here, but again, the time constants need be selected for each baud rate in this case also.
I think, when you are designing a system, you may not always get a universal solution for all situations and one will have to select the appropriate connections to match the system requirements.
the Maxim solution is equivalent to the technique of commercially available products, e. g. as repeater or transparent fibre-optic bridge for PROFIBUS nets. As said, it has to be adapted to the baud rate. Also a minimal idle time of one frame length after each transmission must be guaranteed to disable the repeater/bridge reliable before a new transmission of possibly opposite direction starts.
A lot depends on what type of cable you use. I have achieved > 1000m using Cat5 twisted pair with shielding. Also I connected the gnd between the boards
