The Internal RAM of 51 MCU
nbuzs
Junior Member level 2
I wonder exactly how many sram cells there are in a 51 MCU core.
The data sheet says overlapped 128 upper ram with address 80H~FFH accessed by INDIRECT addressing, while these address space accessed by DIRECT addressing should be SFRs.
So I really puzzled about the Internal RAM and SFRs are exactly uses the same storage cells.
Any help will be appreciate!!
8052 has two pages of upper ram, one, which is directly addressable (SFR Page), other which is indirectly accessible (GPRam), so if you use indirect addressing (eg. through R0 and R1) you actually write to ram, but if you use direct addressing you write to SFR ..
And that is a small catch ..
Rgds,
IanP
    nbuzs
so are the RAM and SFR physically independ while using the same address. Only distinguished by addressing method?
Yes
    nbuzs
