x_stunner
- Joined
- Nov 20, 2013
- Messages
- 5
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 40
Hi everyone and thanks in advance for taking your time and answering me.
I am somehow stuck in a vicious circle and I would really appreaciate it if anyone could ansmer me fully and/or introduce a good book about this problem of mine:
I (I as me and i as current) know that V=Ri and every book says that a resistor is there as a brake in front of electrons to limit the current flow and I also know that if this happens then the "dissipated" power by the resistor equals P=Vi=Rii=VV/R , now by this basic knowledge and these formulas I can't explain the difference between a high power resistor and low power (you know the type the 1/4 watt colorful resistors) ones.
please help me understand why I can't connect a low power 5-Megaohm resistor to a 200-volt home power outlet while the aforementioned formulas say that the current will be 40 microamperes and the power will only be 8 milliwatts which is less than 1/4 of a watt ????
