dineshbabumm
One very basic concept which was troubling me from the begining is the concept of ground in the circuit.Some say ground is a current returning path..
Literally it means having a zero potential.But in actual practice in circuits and all we are giving the negative end as the ground point,or in most of the cases its giving -ve point in the ground.
So this doens't mean we are giving zero potential,but instead we are giving certain amount of -ve potential for sure.For example in biasing the IC's and all we will give +ve point to Vcc and -ve point of the IC to ground.
The -ve terminal of the battery is given to the point where we connect the ground terminal.So this means we are not applying zero potential at all.But ground literally means zero potential. If we use battery,then where is the ground in that??
