cllunlu
Member level 4
- Joined
- Nov 21, 2006
- Messages
- 76
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 1,900
Hello
I am designing a board has ethernet connection and real time clock. I wanna use PIC18F66J65. Already Ethernet connection is there as a internal in pic18f66j65. But I have problem for real time clock application. Before I used DS1307 for microcontrollers that work on the 5V. I didnt satisfeid it.Because usually restart and starts produced date time. I wanted use DS3234. But it is very expensive. Should I use internal rtc via Timer1.
As a result, Can you advise how can I solve RTC problem. Which solution is better and works stable. Or we may change microcontroller models that have ethernet and internal rtc.
Thanks you
Thanks you
