Tetramax Unsupported Construct
baguhan21
Newbie level 2
Newbie level 2
I am running drc check on tetramax then an N2 (unsupported construct) warning was prompted. we have logic libraries that tetramax cant recognize. how can this be solve?
Look at the Customizing Simulation library for ATPG, on solvnet or TMAX online help.
we are working on VLSI designs and the process that was given on the TMAX online help will be too tedious to do.
i check the violations that i encountered and on every library that was read, and it always points to the line "specify".
im thinking that "specify" is causing the unsupported construct error. can anyone verify this and have a solution.
i will be very much in depth. thank you in advance.
tmaxlib is only the Binary file, so I think you are providing the wrog library path, check for the other library or may be there is a tmaxlib library...if there is any tmaxlib library, you can provide that library...because that is only for the TMAX ATPG.So check for that...
