Tetramax add_atpg_constraints and X-free response
aajizattari
Member level 3
Tetramax add_pi_constraints and X-free response
I have a small combinational circuit.
I use add_pi_constraint command to set certain primary inputs of a circuit to X (unknown).
e.g. add_pi_constraint X input1
Because of this constraint, certain outputs will become X.
However, I want to mask the effect of this X and force Tetramax to generate X-free response.
Is that possible?
Re: Tetramax add_pi_constraints and X-free response
Hello,
If we are setting add_pi_constraint to x then It will be surely propagated to the inside of design. First, I would like to know that why you set constraint as X? Generally we are using add_pi_constraints command for defining constant value on top level ports.
