Hi,you only need to disconnect the output of driver and check the outgoing signal with oscilloscope.If the signal is present then it is all okay.The signal should be 1v pp at least.Regards
See datasheet here, **broken link removed** https://www.infineon.com/dgdl/DS_FF...601e3&fileId=db3a304327b8975001280601349b615b
Gate theshhold voltage is around 6V, maximum +-20V and recomended gate voltage is 12-15 volts. So driver shold supply 12 to 15 volt pulse. If it is used at high frequency, it must also be capable of supplying 3-4 amperes to the load.
