danny davis
Banned
- Joined
- Mar 1, 2013
- Messages
- 627
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,296
- Location
- Hollywood
- Activity points
- 0
At work today there is a unit that is blowing a 741 op amp IC in the test fixture
I'm not sure what is causing the 741 op amp IC to get damaged
So my question is how can I SAVE the 741 op amp in the test fixture from getting damaged so I can find where the short is coming from on the PCB board unit?
I changed the 741 OP amp multiple times
Once I hook up the PCB board unit to the test fixture , it will damage the 741 op amp IC inside the test fixture
Can I add fuses on the input and outputs of the 741 op amp IC chip, so a fuse would blow inside of taking out the 741 Op amp?
What value fuses should I use? or can I add a circuit breaker? on the input and output of the 741 Op amp IC chip
What value circuit breaker should I use?
Adding fuses would help me to know where the SHORT is attacking or coming from , is it the input or output or VCC to ground , I'm not sure
