soare_cristian16
Newbie level 2
Tesla coil (audio jack controlled) problem (resonant transformer)
Hello !
For some time I've been trying to make a Tesla coil. Since I didn't have a neon sign transformer, I decided to go on the solid state way.
I've made this schematic: **broken link removed**
The AC signal on the primary circuit is generated by the audio jack from my PC (I've written a program which can give me a sinusoidal / square wave at any frequency). I'm using an old pc speaker amplifier to get the signal powerful enough to operate the mosfet and it's working well (I've tested it with an led). This was my attempt in replacing the old capacitor + spark gap solution with an already tuned AC signal. I hope it isn't a bad idea.
Specifications:
-secondary coil: 2000 turns 0.1 mm, base diametre: 5 cm, L~ 44.8 mH
-C1 is a set of 5 ceramic capacitors in series (each 3kV, 10 nF). The set should work as a 15 kV 2 nF rated capactor. I use this set to bring the coil's resonant frequency at about 17 khz (with a 44100 hz soundcard it gets harder to go above 20 khz)
-primary coil: 3 turns 2 mm
-source: ATX 12 V, 18A (the coil should give me about 8 kV)
-mosfet/power transistor: IRFP260NPBF N channel
After building the coil, I tested it ....and nothing happened... (except the heating of the mosfet)
Could you please help me with some advice ?
If it eventually works, I will be able to modify the signal to generate musical tones. I've started this project to help musical Tesla coil enthusiasts to get the job done without having to know any PIC programming or other alternatives.
Thank you a lot in advance for helping.
Hello !
Specifications:
