Temperature controller
ram_resh
HELLO, we are working on temperature controller project we have written the code in emdedded C and compiled using HItech compiler can you please suggest which programmer kit to be used to dump the hex file on the PIC IC.
I would suggest you first decide on the type of contorller you will be finally using for your application and then look for a programmer.
I have personally used PICKIT3 and found it very easy to use and debug.
hi;you can use AVR microcontroller & lm35 or other same :-Dserie,
