hemnath
Advanced Member level 2
I need to feed a constant current to a pressure sensor. Is it possible to add temperature compensation for this circuit.
I found a note, link https://www.iitr.ac.in/departments/...nics/9. Design of Constant Current Source.pdf
Section: Active current source circuits with good temperature stability. does this circuit is better. should i use transistor or mosfet.
