imhiya
Newbie level 1
Hello,
Just was hoping someone should shine some light on my issue, or give me the correct angle.
Basically, (in theory) I have a 12 bit A/D Temp sensor, this gives a natural bit output ranging from 0 to 4096, -50c to 200c
This is fed into a temp convertor to make it into fahrenheit.
To convert it to fahrenheit, we are given the equation,
Tf approx = ((1.75 * Tc) + 32)
The issue I'm having is, the output of the temp convertor, needs to be 12 bit SIGNED, so ranging from -2048 to 2048. So my problem comes where, I need to convert the input from unsigned to signed, and I've also realised that if a value over 2322 from the A/D temp is fed in, then it will cause the output to be all 1's.
So what is my bed approach, I'll attach my current code.
library ieee;
use ieee.std_logic_1164.all;
use IEEE.numeric_std.ALL;
entity TC_12bit is
port ( CENT_in : in STD_LOGIC_VECTOR(11 downto 0);
FAH_out : out STD_LOGIC_VECTOR(11 downto 0));
end TC_12bit;
architecture behavioural of TC_12bit is
signal Tc : STD_LOGIC_VECTOR(11 downto 0);
signal Tc_shift_r_1 : STD_LOGIC_VECTOR(11 downto 0);
signal Tc_shift_r_2 : STD_LOGIC_VECTOR(11 downto 0);
begin
Tc <= CENT_in;
Tc_shift_r_1(10 downto 0) <= CENT_in(11 downto 1);
Tc_shift_r_1(11) <= CENT_in(11);
Tc_shift_r_2(9 downto 0) <= CENT_in(11 downto 2);
Tc_shift_r_2(11) <= CENT_in(11);
Tc_shift_r_2(10) <= '0';
FAH_out <= std_logic_vector(signed(Tc) + signed(Tc_shift_r_1) + signed(Tc_shift_r_2) + 32);
end behavioural;
