Nov 9, 2006 #1 B babybird Newbie level 6 Joined Feb 15, 2003 Messages 14 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 146 I am doing tcp client project using arm proccessor with uclinux. my tcpclient.c code working when I use switch-hub to connect to server.But can't work when I use cross cable to connect.what do you think about this. thanks for advic
Nov 9, 2006 #2 budhy Advanced Member level 3 Joined Oct 21, 2006 Messages 823 Helped 218 Reputation 436 Reaction score 32 Trophy points 1,308 Location Indonesia Activity points 5,225 Re: Tcp Client Are you sure your cross cable is correct? To make sure, use that cable two connect two computer directly.
Nov 9, 2006 #3 B babybird Newbie level 6 Joined Feb 15, 2003 Messages 14 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 146 Re: Tcp Client Yes I am sure.
Nov 10, 2006 #4 budhy Advanced Member level 3 Joined Oct 21, 2006 Messages 823 Helped 218 Reputation 436 Reaction score 32 Trophy points 1,308 Location Indonesia Activity points 5,225 Re: Tcp Client Connect your device to a computer, and use Ethereal to monitor what happen on the Ethernet bus.
